I use WLED add-ons to control my wled device. There is a a channel called Presets that output either the current selected presets or the list of presets (using a selection in sitemap). This work great, if I choose another in the dropdown, it is sent to the device and the preset is change.
Now, what I would like is to be able to use the same channel to another selection item but when I select something in that selection, it doesn’t send the value to the wled device. My idea is I want to have a way to put a “default preset” that is selected so when my device poweroff, it reset to that preset. I already have all the rule logic for it to work, I just need to have that list (for now I use a button map that I manually map each preset but I would like to have a dynamic list like the current selection).
Is it something possible in openhab?
Thank you!
