I’ve had a pretty stable installation with both zigbee and zwave like once a month they become unavailable. Not knowing exactly why they fall out it is resolved by unplugging and reinserting the usb dongles (or lately by running “usbreset 002/002” to reset the internal usbhub). While I could investigate why they are falling out, it seems hard to solve.
As it happens seldom and is easily fixed by a reset, I was thinking that maybe Openhab could trigger a rule when the error happens? However, I don’t know how to trigger such rule on an error event?
Obviously I am open to other ways of triggering the reset!
Some platform information:
- Platform information:
- Hardware: Intel(R) Core™ i7 CPU L 640 @ 2.13GHz, 4GB
- OS: Ubuntu 22.04.1 LTS
- openHAB version: openHAB 3.3.0.RC1 - docker environment
Docker container configuration:
docker run \
--name openhab \
--net=host \
-v /etc/localtime:/etc/localtime:ro \
-v /etc/timezone:/etc/timezone:ro \
-v /opt/openhab/conf:/openhab/conf \
-v /opt/openhab/userdata:/openhab/userdata \
-v /opt/openhab/addons:/openhab/addons \
-d \
-e USER_ID=997 \
-e GROUP_ID=997 \
-e CRYPTO_POLICY=unlimited \
-e OPENHAB_HTTP_PORT=8081 \
-e OPENHAB_HTTPS_PORT=8444 \
-e EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/zwave:/dev/zigbee" \
--device=/dev/zwave \
--device=/dev/zigbee \
--restart=always \
openhab/openhab:3.3.0.RC1
Openhab.log
2022-10-20 14:55:41.145 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
Events.log
2022-11-04 09:07:59.769 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:57f0bf2477' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to open communications port
2022-11-04 09:07:59.771 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:57f0bf2477' changed from OFFLINE: Failed to open communications port to OFFLINE (COMMUNICATION_ERROR)
lsusb output
Bus 002 Device 021: ID 1a86:7523 QinHeng Electronics CH340 serial converter <= /dev/zigbee
Bus 002 Device 020: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 002 Device 019: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB <= /dev/zwave
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 138a:0007 Validity Sensors, Inc. VFS451 Fingerprint Reader
Bus 001 Device 004: ID 03f0:241d HP, Inc Gobi 2000 Wireless Modem (QDL mode)
Bus 001 Device 003: ID 03f0:231d HP, Inc Broadcom 2070 Bluetooth Combo
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg.txt (269.5 KB)
