These are not the channels for the Things that you show us. I don’t think they’re valid at all, actually.
It’s possible to work out what a channel is called (UID), more like mqtt;topic:Sonoff1:light
but the easy way is to find your Thing in PaperUI and copy/paste the channel UID
Okay, we have a broker-Bridge and a Thing.
But this Thing is not linked in any way to the broker-Bridge. It does not assume anything because you may have more than one broker.
There’s two ways to do this; you can tell each Thing which broker it belongs to.
Or the easier way is to nest Things inside their parent broker with { } braces
Once again, look closely at your events.log to see the names of the Items involved. You’ve got multiple Items here, some are autogenerated and are not the ones you are editing.
Nothing wrong with those items, except the channel links. If you click on your Generic MQTT Things in PaperUI, it should list channels. It’s the channels you want to link to your Items, not the generic Things.
The Item you showed us generating loops in your log was named mqtt_topic_LM1d_LM1d
Maybe that’s changed, but I can’t see the log you’re seeing now.
That’s probably an auto generated Item from your system being in simple mode. I strongly discourage using that setting, it gets in the way of anything you want to do with creating your own configuration.
I think it might hide parts of PaperUI from you as well.
This is the channel UID
That is the part you want to put in the Item’s {channel=‘xxx’} place Switch someItem ... {channel="mqtt:topic:mosquitto:Sonoff1:light"}
Maybe we should see what your casa.items file looks like now. Maybe you can tell us if anything works, or if your log has stopped doing silly things. This is becoming hard work.
Not the same but similar showing the last things I tried but same behavior. 2 lines a second.
I erased items, things and sitemap to start over.
I just don’t know how is the best way to start. Some tutorial are old and they say different methods.
1-Should I use only the Visual Studio and create the files or is better to use Paper UI?
2-What should I create first, Item or Thing?
I never have a Raspberry and I started to deal with this stuff 2 weeks ago. It’s hard to have thins working properly.
When I try to stop the server (sudo systemctl stop openhab2) to clean cache I got this:
Warning: The unit file, source configuration file or drop-ins of openhab2.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
I think that’s not normal. Should I run this daemon-reload?
