I want to create timer that will start when a Switch turned on,
that will turn on the light for 60 seconds, how can i create it?,
or there is an example?
it’s doesn’t work.
i did the following switch:
Switch test “testing” { expire=“10s,command=OFF” }
and it won’t turn off after 10s…
Expire Binding installed ?
my question to.
I changed the quotations marks and it works
Switch test "testing" { expire="10s,command=OFF" }
Its worked, I didn’t know that there is binding like this.
