How to 'createTimer' and 'Timer.cancel' when item change state?
Hi
Are anyone able to see any errors in the above post. I’m having issues with this rule. Sometimes it is working (usually when I’m testing) and other times it will not send a notification.
I’m clueless at the moment as to what I should be looking at.
I tried to put logInfo in the rule, and sometimes I got this:
2016-05-26 21:39:46.514 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'Notifications.rules'
2016-05-26 21:40:01.006 [ERROR] [org.quartz.core.JobRunShell   ] - Job DEFAULT.2016-05-26T21:40:01.004+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@6d9197 (explicitSyntax: true) threw an unhandled Exception:
java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
	at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:67) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
	at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source) ~[na:na]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_75]
	at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.7.0_75]
	at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:751) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
	at sun.reflect.GeneratedMethodAccessor213.invoke(Unknown Source) ~[na:na]
	at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
	at sun.reflect.GeneratedMethodAccessor215.invoke(Unknown Source) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
	at com.sun.proxy.$Proxy78.apply(Unknown Source) ~[na:na]
	at org.openhab.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:44) ~[na:na]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) ~[quartz-all-2.1.7.jar:na]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
2016-05-26 21:40:01.022 [ERROR] [org.quartz.core.ErrorLogger   ] - Job (DEFAULT.2016-05-26T21:40:01.004+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@6d9197 (explicitSyntax: true) threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:224) ~[quartz-all-2.1.7.jar:na]
Caused by: java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
	... 1 common frames omitted
2016-05-26 21:40:02.442 [INFO ] [o.o.m.s.S.                    ] - Timer_null_minutter tilbage
2016-05-26 21:40:08.853 [INFO ] [o.o.m.s.S.                    ] - Timer startet_null_minutter
2016-05-26 21:40:56.901 [INFO ] [o.o.m.s.S.                    ] - Timer_org.openhab.model.script.internal.actions.TimerImpl@3fa960_minutter tilbage
2016-05-26 21:41:47.274 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'Notifications.rules'
2016-05-26 21:45:45.954 [ERROR] [org.quartz.core.JobRunShell   ] - Job DEFAULT.2016-05-26T21:45:45.945+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@e78269 (explicitSyntax: true) threw an unhandled Exception:
org.eclipse.emf.common.util.WrappedException: org.eclipse.xtext.util.PolymorphicDispatcher$NoSuchMethodException: Couldn't find method ''_assignValue'' for objects [JvmVoid:  (eProxyURI: Notifications.rules#xtextLink_::0.2.6.2.0.1.1.0.0.8.7.1.1.0.0::0::/1), <null> <unkown> <XNullLiteralImpl>, null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@1a13e38, org.eclipse.xtext.util.CancelIndicator$1@bddb36]
	at org.eclipse.xtext.util.Exceptions.throwUncheckedException(Exceptions.java:23) ~[na:na]
	at org.eclipse.xtext.util.PolymorphicDispatcher$DefaultErrorHandler.handle(PolymorphicDispatcher.java:41) ~[na:na]
	at org.eclipse.xtext.util.PolymorphicDispatcher.handleNoSuchMethod(PolymorphicDispatcher.java:304) ~[na:na]
	at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:286) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValue(XbaseInterpreter.java:849) ~[na:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(XbaseInterpreter.java:844) ~[na:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_75]
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_75]
	at sun.reflect.GeneratedMethodAccessor206.invoke(Unknown Source) ~[na:na]
Caused by: org.eclipse.xtext.util.PolymorphicDispatcher$NoSuchMethodException: Couldn't find method ''_assignValue'' for objects [JvmVoid:  (eProxyURI: Notifications.rules#xtextLink_::0.2.6.2.0.1.1.0.0.8.7.1.1.0.0::0::/1), <null> <unkown> <XNullLiteralImpl>, null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@1a13e38, org.eclipse.xtext.util.CancelIndicator$1@bddb36]
	... 23 common frames omitted
