How to 'createTimer' and 'Timer.cancel' when item change state?
Interesting but I’ve added the following in the cancellation rule..as you need to cancel a running and not terminated timer but thanks for the Code, ive used it and worked well…just adapted with the below
etc…
if(garagedoor2Timer === null || garagedoor2Timer.hasTerminated)
return;
garagedoor2Timer.cancel() //Terminate timer if door is closed before the timer ends
