Ok thank you, that’s great news.
That said, it seems like it uses python libraries for this - where do I put that python script/rules (what directory?) and do I have to enable python somehow, etc? I cannot seem to find much about about the steps for making sure I have the prerequisites to do this correctly and not break anything.
Can I just put it in the rules folder like it seems to be? Do I need to use both Python and Rules DSL or is it only one of them?
BTW this is my current rule (for daytime), unfortunately it doesn’t do what I want because I have to leave the kitchen for the PIR to switch to off first to get the lights to go to 90%.
var Timer pirKitchenTimer = null
val int pirKitchentimeoutMinutes = 4 // choose an appropriate value
// Kitchen Motion Counter Lights not Evening
rule "Kitchen timed Counter lights PIR Daytime"
Item KitchenMotion changed to ON
if (vTimeOfDay.state !== "EVENING" || vTimeOfDay.state !== "NIGHT") {
if (pirKitchenTimer !== null)
KitchenDimmer.sendCommand(90)
sendCommand(KitchenLightShelf, ON)
pirKitchenTimer.reschedule(now.plusMinutes(pirKitchentimeoutMinutes))
logInfo("Lights","Kitchen light timer rescheduled for " + pirKitchentimeoutMinutes + " minutes")
else
sendCommand(KitchenLightStove, ON)
sendCommand(KitchenLightCounter, ON)
logInfo("Lights","Kitchen light timer created for " + pirKitchentimeoutMinutes + " minutes")
pirKitchenTimer = createTimer(now.plusMinutes(pirKitchentimeoutMinutes))
if (KitchenMotion.state == ON)
logInfo("Lights","Kitchen timer triggered, but rescheduled again for " + pirKitchentimeoutMinutes + " minutes")
else
logInfo("Lights","Kitchen light timer expired")
sendCommand(KitchenLightStove, OFF)
sendCommand(KitchenLightCounter, OFF)
sendCommand(KitchenLightShelf, OFF)
KitchenDimmer.sendCommand(OFF)
I’ve attempted to adapt the Design pattern timer rule to my situation, and it triggers the first part accordingly but doesn’t reschedule the timer and turn on the lights to full, it just lets the initial timer expire (30s) and turns off the lights again.
var Timer occupancyTimer = null
var int rescheduleminutesadded = 5
rule "Kitchen lights PIR Daytime"
Item KitchenMotion received update ON
if(vTimeOfDay.state !== "EVENING" || vTimeOfDay.state !== "NIGHT" && occupancyTimer === null || occupancyTimer.hasTerminated())
logInfo("Kitchen Lights","Kitchen counter light timer created for 30 seconds")
occupancyTimer = createTimer(now.plusSeconds(30),
KitchenMotion.sendCommand(OFF)
else
occupancyTimer.reschedule(now.plusMinutes(rescheduleminutesadded))
logInfo("Kitchen Lights","Kitchen light full + timer rescheduled for " + rescheduleminutesadded + " minutes")
Log:
2020-01-18 11:43:00.826 [INFO ] [marthome.model.script.Kitchen Lights] - Kitchen counter light timer created for 30 seconds
2020-01-18 11:43:00.838 [ome.event.ItemCommandEvent] - Item 'KitchenLightStove' received command ON
2020-01-18 11:43:00.841 [ome.event.ItemCommandEvent] - Item 'KitchenLightCounter' received command ON
2020-01-18 11:43:00.850 [vent.ItemStateChangedEvent] - KitchenLightStove changed from OFF to ON
2020-01-18 11:43:00.851 [vent.ItemStateChangedEvent] - KitchenLightCounter changed from OFF to ON
2020-01-18 11:43:14.898 [vent.ItemStateChangedEvent] - Azimuth changed from 167.98259991498603 to 168.23692591300428
2020-01-18 11:43:14.908 [vent.ItemStateChangedEvent] - Elevation changed from 24.802973282532456 to 24.840339074596336
2020-01-18 11:43:14.911 [vent.ItemStateChangedEvent] - DiffuseRadiation changed from 109.45523989362364 to 109.5220650077409
2020-01-18 11:43:14.914 [vent.ItemStateChangedEvent] - TotalRadiation changed from 282.93861299503527 to 283.5482320912065
2020-01-18 11:43:15.169 [vent.ItemStateChangedEvent] - SCHNELLPIXEL3Uptime changed from 66358 to 66372
2020-01-18 11:43:15.174 [vent.ItemStateChangedEvent] - SCHNELLPIXEL3LastSeen changed from 2020-01-18T11:42:54.000-0500 to 2020-01-18T11:43:08.000-0500
2020-01-18 11:43:15.187 [vent.ItemStateChangedEvent] - KLAUDIASAMSUNGLastSeen changed from 2020-01-18T11:42:54.000-0500 to 2020-01-18T11:43:08.000-0500
2020-01-18 11:43:19.375 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:5f9ec1b3_ed59_1900_4530_00a0deb68d70:Main_Zone' has been updated.
2020-01-18 11:43:25.222 [vent.ItemStateChangedEvent] - SCHNELLPIXEL3Uptime changed from 66372 to 66384
2020-01-18 11:43:25.227 [vent.ItemStateChangedEvent] - SCHNELLPIXEL3LastSeen changed from 2020-01-18T11:43:08.000-0500 to 2020-01-18T11:43:20.000-0500
2020-01-18 11:43:25.237 [vent.ItemStateChangedEvent] - KLAUDIASAMSUNGLastSeen changed from 2020-01-18T11:43:08.000-0500 to 2020-01-18T11:43:20.000-0500
2020-01-18 11:43:30.611 [ome.event.ItemCommandEvent] - Item 'DenDeskLED' received command ON
2020-01-18 11:43:30.660 [ome.event.ItemCommandEvent] - Item 'DenDeskLED' received command ON
2020-01-18 11:43:30.833 [INFO ] [clipse.smarthome.model.script.Lights] - Kitchen light timer expired
2020-01-18 11:43:30.849 [ome.event.ItemCommandEvent] - Item 'KitchenMotion' received command OFF
2020-01-18 11:43:30.850 [nt.ItemStatePredictedEvent] - KitchenMotion predicted to become OFF
2020-01-18 11:43:30.867 [ome.event.ItemCommandEvent] - Item 'KitchenLightStove' received command OFF
2020-01-18 11:43:30.871 [ome.event.ItemCommandEvent] - Item 'KitchenLightCounter' received command OFF
2020-01-18 11:43:30.881 [ome.event.ItemCommandEvent] - Item 'KitchenLightShelf' received command OFF
2020-01-18 11:43:30.893 [ome.event.ItemCommandEvent] - Item 'KitchenDimmer' received command OFF
2020-01-18 11:43:30.894 [vent.ItemStateChangedEvent] - KitchenMotion changed from ON to OFF
2020-01-18 11:43:30.903 [nt.ItemStatePredictedEvent] - KitchenLightShelf predicted to become OFF
2020-01-18 11:43:30.911 [nt.ItemStatePredictedEvent] - KitchenDimmer predicted to become OFF
2020-01-18 11:43:30.918 [vent.ItemStateChangedEvent] - KitchenLightStove changed from ON to OFF
2020-01-18 11:43:30.920 [vent.ItemStateChangedEvent] - KitchenLightCounter changed from ON to OFF
