Hi @ all,
maybe someone can help?
I’m still on openhab 2.5 and i want to create a rule which changes the value of a string.
(or if someone has another solution)
I have a Sony Android TV and installed the Sony Binding.
I need to send a IR Remote control via Sony IRCC interface by network.
The Sony Binding has a string and i need to change the string to “AAAAAgAAAJcAAAAZAw==”
Thats the pause button.
A item sony_pause should switch pause on and off (so if i watch netflix or any HDMI CEC device i can pause by alexa)
I createt a item as a switch and alexa can turn on and off the switch. But i need to create the rule which changes the string.
The String is:
“String IRCC_Command “Command [%s]” { channel=“sony:ircc:home:primary#command” }”
The Binding info page:
At the moment it looks like that:
rule “sony_pause”
Item sony_pause received update “ON”
if(receivedCommand == ON) IRCC_Command(“AAAAAgAAAJcAAAAZAw==”)
The logfile output:
15:42:12.507 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘sony_pause’ received command ON
15:42:12.507 [INFO ] [smarthome.event.ItemStateChangedEvent] - sony_pause changed from OFF to ON
15:42:12.523 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule ‘sony_pause’: The name ‘receivedCommand’ cannot be resolved to an item or type; line 5, column 6, length 15
