I have an MQTT433Gateway.
I want to link an item to the MQTT message. The problem is the payload looks like this:
{“id”:6, “unit”:2, “state”:“on”}
The curly brackets are part of the payloud.
How should the item definition look like?
Thanks.
Thanks.
Make a topic like …/6/2 or make it one string („id:6,unit:2,state:on”) and send it all as payload.
Actually I want to receive that payload and understand it.
I solved it with the Json manipulation extension. Now my item is like this:
mqtt="<[mosquitto:rf434/recv/conrad_rsl_switch/6:state:JSONPATH($.state)]"}
Ah o.k., because it’s a string you have to provide a string item for receiving:
String receive_mqtt_message "MQTT Teststring [%s]" <info> {mqtt="<[<broker>:test/string:state:default]"}
Frame label="Test" {
Text label="Test" icon="info" {
Switch item=testSwitch mappings=[ON="Ein", OFF="Aus"]
Text item=testString
Then you have to extract from this string the values you need. Looks like that.
