does anybody know, how I can define metadata with subkeys in my item files? With the helper libraries for openHAB Scripted Automation its not a big deal, but in an item file I was not able to do so. I also like to know if or how I can define the metadata without the value and just the config if possible in an item file.
Thx for your example, but that’s not what I wanted. You have no subkeys just plain key-value-pairs. Seems I can’t defined what I want to define in an item file. In the example “Area Triggers and Actions” of the helper libraries for openHAB Scripted Automation I found the following text:
It is possible to add simple Metadata to Items through .items files, but this is very limited and does not support the hierarchical key structures used here.
