Sorry my fault.
Sound like a job for CSS mabe this thread can help a little.
A setup like followin:
Switch SwitchingItem
Contact StateItem_status
Switch StatusItem_state
But you would still need a rule which starts a timer when SwitchingItem gets an command and waits maybe 0,5 seconds if you receive a SteteItem change do nothing, if not set StatusItem to off.
Then use teh proposed sheme the you can shange the UI of the button with css.
Edit: changed the broken link.
Maybe this thread can give you more insight in the css.
I never did CSS on habpanel. I only use basic UI for now.
