it is possible to draw a graph of the calculated average values of a group like this:
Group:Number:AVG gKeller_Temp "Temperatur Durchschnitt [%.2f °C]" <temperature> (All)
How do i do this?
Sebastian
How do i do this?
Sebastian
You would have to persist the group itself, so use
gKeller_Temp : everyChange, everyMinute
as persistence strategy.
I tried this already.
The item is gKeller_Temp
and as chart it draws all group members in one chart. This is pefect.
Now i want a different chart with only the calculated average.
Argh… that’s correct… You’ll have to copy the group state to another (proxy) item. just define an item:
Number aKeller_Temp
and a rule to update:
rule "update aKeller_Temp"
Item gKeller_Temp changed
aKeller_Temp.postUpdate(gKeller_Temp as DecimalType)
and persist the proxy item.
Hmm,
casting GroupItem to DecimalType does not work. I think tried also this a while ago
Error during the execution of rule 'update aKeller_Temp': Cannot cast org.openhab.core.items.GroupItem to org.openhab.core.library.types.DecimalType
OK, i get it.
The update function has to be:
aKeller_Temp.postUpdate(gKeller_Temp.state as DecimalType)
Argh… yes, missed the .state …
