I am new here and need some help.
How can input be edited in the openHAB UI yet - anyone got any bright ideas?
It depends on the input i.e. if you have a number, you could use a setpoint item to change it’s value, or maybe set up an item with buttons:
.items
Number Set_Value "Set Value" {autoupdate="false"}// proxy item
Number MyItem "My Item is [%s]"
.sitemap
Switch item=Set_Value mappings=[-10="-10",-1="-1",1="+1",10="+10"]
.rules
rule "Set the Value"
Item Set_Value received command
switch (receivedCommand) {
case -10 : MyItem.sendCommand((MyItem.state as DecimalType)-10)
case -1 : MyItem.sendCommand((MyItem.state as DecimalType)-1)
case 1 : MyItem.sendCommand((MyItem.state as DecimalType)+1)
case 10 : MyItem.sendCommand((MyItem.state as DecimalType)+10)
default : logInfo("Set_Value","Wrong value: {}",receivedCommand.toString)
This would result in an Item with four buttons. Every time you press one of these buttons, the value of MyItem will change accordingly.
There is no way to get a free input from the UI, though you could build a webpage with text input which will push it’s input through REST to openHAB, and then integrate this webpage with the webview widget to openHAB. (sure, a huge workaround.)
thanks
Thanks Udo.
I have an issue and getting this message:
Cannot cast org.openhab.core.types.UnDefType to
org.openhab.core.library.types.DecimalType
Probably issue with initialization. Any thoughts?
Ah, yes. You can catch this in different ways. The first option is, set MyItem to 0 (or any other start value) at startup:
rule "start openHAB"
System started
MyItem.postUpdate(0)
Or you can catch the Issue with this line between then
and switch
in the “set the value” rule:
if (!(MyItem.state instanceOf DecimalType)) MyItem.postUpdate(0)
The best Option probably would be to persist and restoreOnStartup MyItem with mapdb for example. (in addition to the second option, to initialize MyItem one-time.
