If I edit rrd4j.persist with Eclipse SmartHome Designer and save it, I got this error message:
2017-05-21 17:52:45.896 [ERROR] [.core.internal.folder.FolderObserver] - Error handling update of file ‘C:\OpenHAB2\conf\persistence\rrd4j.persist’: null.
java.lang.NullPointerException
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.removeFutures(ExpressionThreadPoolManager.java:321)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.remove(ExpressionThreadPoolManager.java:291)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.remove(ExpressionThreadPoolManager.java:308)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.removeTimers(PersistenceManagerImpl.java:321)[103:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stopEventHandling(PersistenceManagerImpl.java:377)[103:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.removeConfig(PersistenceManagerImpl.java:348)[103:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.model.persistence.internal.PersistenceModelManager.modelChanged(PersistenceModelManager.java:85)[125:org.eclipse.smarthome.model.persistence:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
It looks like Eclipse SmartHome Designer blocks openhab to use the file correct. If I use another editor to edit the file it looks like the file is opened in another mode that openhab is able to read the file even it is open.
My problem is, that I cannot edit the file with Eclipse SmartHome Designer because the changes are not used. I have to open the file with a different editor and save it again to be able to use it correct by openhab
2017-05-21 17:53:00.558 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘rrd4j.persist’
any idea?
