Java Runtime Environment: which java platform is used and what version
openHAB version:
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
How do you enable to start logging into files in openhab 3 (openhabian)?
Yes, I’ve searched community and also looked at official documentation: Logging | openHAB
It says “manual”, but what is manual? Edit log4j2.xml file?
But I really do not understand how to enable it in log4j2.xml file.
There is no LOG folder in openhab/userdata
Spent 3 hours on this already but I’d rather tell everyone I’m not understanding it than spend more time in the dark.
It does so by default already. Where it logs to depends on how OH is installed. If you are using openHABian, you didn’t install OH using the manual installation instructions. Have you looked in /var/log/openhab?
