I browsed to all timer examples here but I do not found an solution for my problem.
I want to stop a timer instead of just cancel it. Because I want that all command should run if the timer runs to the end or manually set to end before time runs out
What I tried:
Timer rule log something at the end of timer
tTimer = createTimer(now.plusSeconds(120))
logInfo(“TIMERCHECK”,“TIMERCHECK: End timer”)
tTimer = null
This will reschedule the timer, works perfect
tTimer.reschedule(now.plusSeconds(120))
This will cancel the timer, works perfect, but does not run the command
tTimer.cancel()
I’m searching for something like
tTimer.stop()
This will stop the timer before time is reached and runs the command
Is this possible and is there a documentation available what commands timer can handle. I looked at xtend, java, but do not find it there. Any hint?
