import org.openhab.model.script.actions
import org.openhab.core.library.types
import java.util
rule "check chromecast state"
Item chromecast_audio_473325b22fd70ba5c3e51dd0d503fc7c_control changed
var String command = chromecast_audio_473325b22fd70ba5c3e51dd0d503fc7c_control.state.toString
if (command.contains("PLAY"))
logInfo("TEST","Chromecast is playing")
else if (command.contains("PAUSE"))
logInfo("TEST","Chromecast is paused")
Could you help me out here? When you say you are using this for streaming iHeart, do you mean you are streaming iHeart from a phone or tablet, separate from OH? Or do you actually have music steaming integrated into OH? (I would love to see how this works, if so.)
And I have the CCast binding installed, and channels active. But I am really just starting with Rules. Can you tell me what else i need to make use of it? ie, scripts, items, sitemap entry etc?
