I was wondering if someone could help me out. I wanted to see if it’s possible that if two actions occur within a certain time frame then turn some lights on.
Basically, I want certain lights to turn on when the following two events happen within 5 minutes of each other:
Phone is updated to ON
Front door sensor is updated to OPEN
var Timer phoneTimer = null
var Timer doorTimer = null
rule "Phone updated to ON"
Item Phone received update ON
// Timer is running, the door sensor triggered five minutes or less ago
if(doorTimer != null && !doorTimer.hasTerminated){
Lights.sendCommand(ON)
// Create a Timer for the other event
else {
phoneTimer = createTimer(now.plusMinutes(5), [| phoneTimer = null])
rule "Door updated to ON"
Item Door received update ON
if(phoneTimer != null && !phoneTimer.hasTerminated){
else {
doorTimer = createTimer(now.plusMinutes(5), [| doorTimer = null])
It could be further collapsed using a lambda but I wanted to keep this simple.
Theory of Operation:
When one of the sensors triggers, it sets a five minute Timer. When the other sensor triggers, it looks to see if there is a running Timer for the other sensor. If there is we know that the other sensor went off less than five minutes ago so turn on the light. The Timer itself doesn’t do anything but reset itself to null when it expires.
