Let’s say i define channel in .things file as :
Switch : status [ out-transform=“MAP(default_out.map)”, in-transform=“MAP(default_in.map)” ]
and in the channel-config:
> <channel-type id="status">
> <item-type>Switch</item-type>
> <label>Switch</label>
Question is, how to get the Item-Type (i.e. Switch) from this overwrite function: @Override
public void channelLinked(ChannelUID channelUID) { }
Somehow i want to use this information to decide whether this channel supports state or command or both instead of providing another parameter for user to key in and decide, e.g. in-type, out-type. Thanks
