How to fix error Temp on UI Basic
Hi guy!
I have set up the item and displayed the sonoff basic temperature via mqtt, but in addition to the sitemap, I reported an error
How to fix it.
It does not error in the control
55%20PM
Hard to tell without more info about Item and channel, but it looks like you just load some JSON into a string type Item state.
You probably need to look into using JSONPath with MQTT.
thanks @rossko57
I only use the setup interface, and this is JSONPATH.
Your Incoming Value tranformation does not match the syntax description below. Please reread the hint and correct the transformation.
@job
Sorry, I have not really figured out the problem, can you give me an example for my case?
You are using brackets while the example uses a colon.
JSONPATH( ) vs. JSONPATH:
thanks @job
Only successful Humidity, when I change it to JSONPATH: $. DHT11. Humidity
And I was really confused when the temperature didn’t work again. This is jsonpath: JSONPATH: $. DHT11.Temperature
Both are text items. and my sitemap
Frame label=“weather” {
Text item=Bedroom_Temperature label=“Outside Temperature [%.1f °C]” icon=“temperature”
Text item=Bedroom_Humidity label=“Outside Humidity [%d %%]” icon=“humidity”
01%20PM
You cannot use the %.1f decimal format on a string Item state, it’s a string
thanks @rossko57
Great, I created a new item with the number format and it work. Maybe, I tried to link to an old item that was not a Number and I have not discovered.
