How to format quantity type in rules?
How do I format quantity type in rules? I have the following item:
Number:Power                Output_power                 "Output Power [%.2f kW]"                   (gEaseeBox)           {channel="xxxxxxxxxxxxxxxxxxxxxxx", unit="kW"}
In the rules I’m logging the value, it prints too many digits after decimal points (looks like item formatting doesn’t apply for rules):
Charging has started at speed 10.767000198364258 kW
Now I try this:
logInfo("Tesla", "Charging has started at speed " + String.format("%.2f", Output_power.state.))
But I got the follow error:
Script execution of rule with UID 'Tesla-1' failed: f != org.openhab.core.library.types.QuantityType in Tesla
Any hints? Thanks in advance!
logInfo("Tesla", "Charging has started at speed " + Output_power.state.format("%.2f %unit%"))
Thanks, I tried the following:
    var totalPower = (Output_power.state as QuantityType<?>).toUnit('kW')
    var powerPct = new PercentType((totalPower/maxChargingSpeed).toBigDecimal*100)
    logInfo("EaseeBox", "The charging power has changed to {}, corresponding to charging power pct {}", totalPower.format("%.2f %kW%"),  powerPct)
However I see the error:
Script execution of rule with UID 'EaseeBox-2' failed: Conversion = 'k' in EaseeBox
    logInfo("EaseeBox", "The charging power has changed to {}, corresponding to charging power pct {}", totalPower.format("%.2f %unit%"),  powerPct)
The %unit% is actually literally that. Don’t replace it with kW. It will be replaced by format with the actual unit that the variable currently holds.
Works thanks a lot!
