I am currently trying to create multi room timers for Alexa using the Amazon Echo Control binding.
My problem is how can I get alexa to speak a variable text ?
This would be my text:
val String formattedTimeAboveOneHour = "You got" + totalHours + "hours and" + remainderMins + " Minutes left on your" + durationTimer + "minutes timer"
How can I let alexa speak this variable text using rules DSL?
Someone said he got it working but sadly he did not exactly post how and I think he did it with node red and not with the rules DSL. ([SOLVED] Get Alexa to speak a variable text)
val formattedTimeAboveOneHour = "You got" + totalHours + "hours and" + remainderMins + " Minutes left on your" + durationTimer + "minutes timer"// don't cast unless you have to... the DSL will be happier when it can figure things out for itself
TTS_Item.postUpdate(formattedTimeAboveOneHour)
Sorry I didn’t know you wanted a few examples. Looks like Scott got you pointed in the right direction but I can post a couple of DSL rules if you like.
