I am using OH on a windows server with the version 5.1.4. I do have the doorbird doorstation D1101V-F which has an app where I can enable an external videostream service (NVR) which receives either H.264 or MJPEG.
Which binding I need to use to receive the video stream of this doorbird camera? The problem with the doorbird binding is, that the video framerate is very poor with 1-2s.
IP camera binding has a doorbird integration. And the documentation page mentions how to have a video widget.
And you can also use a dedicated NVR like Frigate if you want advanced features. Frigate handles doorbird devices, and there is a Frigate binding on the marketplace.
Alternatively, if you run a CCTV app such as Zoneminder, you can feed the Doorbird video stream directly into Zoneminder so it shows up in Zoneminder as just another camera. I have my Zoneminder set up to continuously record the Doorbird stream so I never miss anything that happens at the front door.
@GwendalGwendal: Could you explain what you mean with “IP camera binding has a doorbird integration”?
Do you refer to the doorbird binding or the IP-camera binding? I try to use the doorbird binding but it does not use a real live stream with only very poor fps.
