How to get "Weekday" in a rule which works?
I am using in OH 4M3 a rule which simply should check the day of a week. For some reason I do get an error message. Here my rule:
rule "Einschlafmusik"
    Item PowerSqueezebox_chn3 received command
    if(receivedCommand == ON) {
		val day = now.getDayOfWeek.getValue()
	    if (day == 1)
			SqueezeBox_Player_Play_a_Favorite.sendCommand("0")
			SqueezeBox_Player_Volume.sendCommand(11)
		else (day == 7)
			SqueezeBox_Player_Play_a_Favorite.sendCommand("15")
			SqueezeBox_Player_Volume.sendCommand(15)
			logInfo("Montag - Z2_Regen3")
    } else {
        SqueezeBox_Player_Stop.sendCommand("ON")
and the error:
[INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'musik.rules', using it anyway:
This expression is not allowed in this context, since it doesn't cause any side effects.
[ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'musik-1' failed: An error occurred during the script execution: index=1, size=1 in musik
Can anybody help pls?
Try
now.getDayOfWeek.toString()
I use a virtual.items
String vDayOfWeek "Current Day of Week [%s]"
Rule:
rule "00_00"
        Time cron "0 0 0 ? * * *" // 00:00
        vDayOfWeek.sendCommand(now.getDayOfWeek.toString())
        logInfo("System", "DAY=" + now.getDayOfWeek)
Other rule:
if ((vDayOfWeek.state.toString != "SATURDAY") && (vDayOfWeek.state.toString != "SUNDAY")) {
// do stuff
I use the UI and ECMAScript 262 (OH4)
var datetoday = new Date();
var numberofweek = datetoday.getDay();
if ((numberofweek != 0) || (numberofweek != 6)){
console.log("It is a weekday")
I just run the rule every day.
I am sure there are many better ways as well that work.
In my openhab3 installation I have a rule with
if (now.getDayOfWeek.getValue == 7) SqueezerKueche_PlayaFavorite.sendCommand (0)
		else SqueezerKueche_PlayaFavorite.sendCommand (7)
and this works for me.
Greets
There are a lot of good answers here. I just want to point out that for any questions about how ZonedDateTimes work in Rules DSL see ZonedDateTime (Java SE 17 & JDK 17).
In JS Scripting see Reference | js-joda.
What OP has above should work. The getValue() returns an int representation of the day of the week.
Don’t forget about Ephemeris and the isWeekend Action. Actions | openHAB
if(isWeekend()){
In JS Scripting the Ephemeris call would be
if(actions.Ephemeris.isWeekend()){
To get the day of the week using the Helper Library:
var numberofweek = time.toZDT().dayOfWeek().value();
Also, don’t forget that you have Time based conditions in MainUI Rules where you can limit when rules run based on days of the week or Ephemeris.
Now, back to the original post…
Are you sure the error is coming from this rule? The error indicates trying to access something from a List or an array out of bounds and there is nothing like that in this rule.
don’t you need an ‘if’ as in “else if (day == 7)”?
Very sharp eye. Yes indeed an if is required here.
Good point! Thanks
If @jswim788 was the root cause of the problem, the solution should go to that post, not mine.
