As I’m setting up my ChannelTypeProvider I’m contemplating how to handle the many asymmetric cases I have.
For example, a symmetric case is where you have a simple switch. The switch has two position, on and off. So, there are two commands you would send to the channel, on and off. Subsequently, because it’s symmetric, the status you would get on the channel would be on and off.
But when commands and status is asymmetric, then what? Take for example the lamp on a projector. There are two possible commands, on and off. However, there are 4 different statuses. When I command the projector to turn on, the lamp should come back with a status of on, but when I command the lamp to turn off, the status will at first come back “cooling”. During the cooling status the power switch should be disabled because power state commands are invalid in that state. Finally, the projector will decide it’s sufficiently cool and the status will change to off, which then allows the on command to be re-enabled. Then there is “Emergency” status, which is an asynchronous status that basically means the projector is off-line until the condition has been dealt with and manually cleared.
How would such channel be defined? It didn’t seem possible to designate values that are specific to commands and those that are specific to status. How should this be handled?
–TIA
