I am looking to enabled/install the regex transformation via the console.
I am running 3.2.0.M2
openhab> feature:list|grep transform
openhab-transformation-bin2json x 3.1.0 x x Uninstalled x openhab-addons-3.1.0 x Binary To JSON Transformation
openhab-transformation-exec x 3.1.0 x x Uninstalled x openhab-addons-3.1.0 x Exec Transformation
openhab-transformation-javascript x 3.1.0 x x x Started x openhab-addons-3.1.0 x Javascript Transformation
openhab-transformation-jinja x 3.1.0 x x Uninstalled x openhab-addons-3.1.0 x Jinja Transformation
openhab-transformation-jsonpath x 3.1.0 x x x Started x openhab-addons-3.1.0 x JSONPath Transformation
openhab-transformation-map x 3.1.0 x x x Started x openhab-addons-3.1.0 x Map Transformation
openhab-transformation-regex x 3.1.0 x x x Started x openhab-addons-3.1.0 x RegEx Transformation
openhab-transformation-scale x 3.1.0 x x x Started x openhab-addons-3.1.0 x Scale Transformation
openhab-transformation-xpath x 3.1.0 x x Uninstalled x openhab-addons-3.1.0 x XPath Transformation
openhab-transformation-xslt x 3.1.0 x x Uninstalled x openhab-addons-3.1.0 x XSLT Transformation
openhab> feature:install ....
Am I missing something?
gogo: CommandNotFoundException: Command not found: feature:listopenhab>
Yes, the karaf console
[root@openhab items]$ ssh -p 8101 openhab@localhost
Password:
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.2.0.M2 - Milestone Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
openhab>
Bundle:list works⦠perhaps ID 189 is part of my problem?
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID β State β Lvl β Version β Name
βββββΌβββββββββββΌββββββΌββββββββββββββββββββββββΌβββββββββββββ
31 β Active β 80 β 2.12.3 β Jackson-annotations
32 β Active β 80 β 2.12.3 β Jackson-core
33 β Active β 80 β 2.12.3 β jackson-databind
34 β Active β 80 β 2.12.3 β Jackson-dataformat-YAML
35 β Active β 80 β 2.12.3 β Jackson datatype: JSR310
36 β Active β 80 β 6.2.4 β Woodstox
37 β Active β 80 β 2.8.6 β Gson
38 β Active β 80 β 27.1.0.jre β Guava: Google Core Libraries for Java
39 β Active β 80 β 30.1.0.jre β Guava: Google Core Libraries for Java
40 β Active β 80 β 1.0.1 β Guava InternalFutureFailureAccess and InternalFutures
41 β Active β 80 β 3.0.0.v201312141243 β Google Guice (No AOP)
43 β Active β 80 β 4.8.35.v20190528-1517 β ClassGraph
189 β Waiting β 80 β 3.2.0.M2 β openHAB Core :: Bundles :: Karaf Integration
Its the only one that says βWaitingβ.
Here are some of the logs (related to βkarafβ and βfeatureβ) which may help:
2021-10-28 05:06:00.190 [INFO ] [ROOT] - bundle org.apache.felix.scr:2.1.26 (72) Starting with globalExtender setting: false
2021-10-28 05:06:00.198 [INFO ] [ROOT] - bundle org.apache.felix.scr:2.1.26 (72) Version = 2.1.26
2021-10-28 05:06:00.290 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.bundle.core/4.3.2
2021-10-28 05:06:00.339 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.config.core/4.3.2
2021-10-28 05:06:00.578 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.diagnostic.core/4.3.2
2021-10-28 05:06:00.598 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.features.command/4.3.2. Missing service: [org.eclipse.equinox.region.RegionDigraph, org.apache.karaf.features.FeaturesService]
2021-10-28 05:06:00.630 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.http.core/4.3.2. Missing service: [org.apache.karaf.http.core.ServletService, org.apache.karaf.http.core.ProxyService]
2021-10-28 05:06:00.657 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.instance.core/4.3.2
2021-10-28 05:06:00.676 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.kar.core/4.3.2. Missing service: [org.apache.karaf.kar.KarService]
2021-10-28 05:06:00.696 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.log.core/4.3.2. Missing service: [org.apache.karaf.log.core.LogService]
2021-10-28 05:06:00.708 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.package.core/4.3.2
2021-10-28 05:06:00.789 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.log.core/4.3.2
2021-10-28 05:06:00.808 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.log.core/4.3.2
2021-10-28 05:06:00.814 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.log.core/4.3.2
2021-10-28 05:06:00.834 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.service.core/4.3.2
2021-10-28 05:06:01.070 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.shell.ssh/4.3.2. Missing service: [org.apache.sshd.server.SshServer]
2021-10-28 05:06:01.104 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.system.core/4.3.2
2021-10-28 05:06:01.184 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.http.Http1FieldPreEncoder of service org.eclipse.jetty.http.HttpFieldPreEncoder in bundle org.eclipse.jetty.http
2021-10-28 05:06:01.242 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.security.jaspi.JaspiAuthenticatorFactory of service org.eclipse.jetty.security.Authenticator$Factory in bundle org.eclipse.jetty.security.jaspi
2021-10-28 05:06:01.300 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.ssh/4.3.2
2021-10-28 05:06:01.317 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.identity.IdentityExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2021-10-28 05:06:01.321 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.fragment.FragmentExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2021-10-28 05:06:01.324 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.PerMessageDeflateExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2021-10-28 05:06:01.327 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.DeflateFrameExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2021-10-28 05:06:01.328 [INFO ] [rg.apache.aries.spifly.BaseActivator] - Registered provider org.eclipse.jetty.websocket.common.extensions.compress.XWebkitDeflateFrameExtension of service org.eclipse.jetty.websocket.api.extensions.Extension in bundle org.eclipse.jetty.websocket.common
2021-10-28 05:06:02.493 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.event/4.3.2
2021-10-28 05:06:03.069 [INFO ] [rvice.jetty.internal.JettyServerImpl] - Pax Web available at [0.0.0.0]:[8443]
2021-10-28 05:06:03.091 [INFO ] [vice.jetty.internal.JettyFactoryImpl] - No ALPN class available
2021-10-28 05:06:03.092 [INFO ] [vice.jetty.internal.JettyFactoryImpl] - HTTP/2 not available, creating standard ServerConnector for Http
2021-10-28 05:06:03.093 [INFO ] [rvice.jetty.internal.JettyServerImpl] - Pax Web available at [0.0.0.0]:[8080]
2021-10-28 05:06:03.098 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.apache.karaf.http.core_4.3.2 [82]] to http service
2021-10-28 05:06:03.134 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.ops4j.pax.web.pax-web-extender-whiteboard_7.3.16 [221]] to http service
2021-10-28 05:06:03.141 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - created whiteboard from configuration: {service.pid=org.apache.aries.jax.rs.whiteboard.default}
2021-10-28 05:06:03.157 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.http.core/4.3.2
2021-10-28 05:06:03.422 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.apache.aries.jax.rs.whiteboard_2.0.0 [63]] to http service
2021-10-28 05:06:08.293 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.openhab.core.karaf/3.2.0.M2
2021-10-28 05:06:08.303 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.3.2
2021-10-28 05:06:08.307 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.3.2
There are no errors that I can see other than me writing a super long value to the database:
2021-10-28 07:00:49.957 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Data too long for column 'value' at row 1
Query is: INSERT INTO item0038 (TIME, VALUE) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Query: INSERT INTO item0038 (TIME, VALUE) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Parameters: [iVBORw0KGgoAAAANSUhEUgAABQAAAAQACAIAAAAx8WMUAAAgAElEQVR4nOzdd5zd9X3n++/3106b
In case its importantβ¦
Ubuntu 18.04.6 LTS (Bionic Beaver)
[root@openhab items]$ /usr/bin/java -version
openjdk version "11.0.13" 2021-10-19 LTS
OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
OpenJDK 64-Bit Server VM Zulu11.52+13-CA (build 11.0.13+8-LTS, mixed mode)
[root@openhab ~]$ apt show openhab
Package: openhab
Version: 3.2.0~M3-1
Priority: optional
Section: java
Source: openhab
Maintainer: https://community.openhab.org
Installed-Size: 110 MB
Depends: adduser
Recommends: zip, unzip
Suggests: default-jre | java11-runtime | java11-runtime-headless
Conflicts: openhab2, openhab-runtime, openhab2-online, openhab2-offline
Breaks: openhab2 (<< 3.0.0~)
Replaces: openhab2 (<< 3.0.0~)
Homepage: www.openhab.org
Download-Size: 99.3 MB
APT-Sources: https://openhab.jfrog.io/artifactory/openhab-linuxpkg testing/main amd64 Packages
Description: openhab
Linux installation package for openHAB.
My solution was to reinstall Openhab from package.
sudo apt-get install --reinstall openhab openhab-addons
Did the trick, can run βfeature:listβ no problem. Sorry for the spamming.
