I have a node device which I use HTTP get command to check if it is on or off (simple healthcheck). I thought of using switch item that will send http get command and based on response will set it state (on / off). Th eissue is that if the node device is off and doesn’t respond, the http binding fails and the switch item doesn’t change it state to off.
I think I can use a rule for that to solve this issue but maybe there is a better way to do it.
(Note that I am checking if the application running on the node is alive and note if the device itself is on or off, otherwise I would have used network binding).
Thx for any advice
