I have searched and googled alot, but could not find an answer to my issue.
I recently started to fiddle with habPanel so please bear with me, in case this is a beginner’s question.
I have the following situation.
I have several contact items (windows), which I want to group, to have a general indication that in a certain room (e.g. livingroom) all windows are closed. I have setup a group item in openHAB and have added my contact items to said group.
The group is setup with a function so that a single non “CLOSED” window contact will put the whole group in state OPEN.
This all seems to work fine. When opening one of the windows, I can see that in openHAB event log the corresponding contact item changing it’s state, as well as the group.
I have now two widgets in habpanel, one containing all the contacts directly, and one that contains just the group. The problem is, that upon state change of a contact, only the widget with the discreet states is updated. The widget showing the group is not updated, and will only show the current state after a manual refresh.
I checked via Chromes debug tools, that the event stream reaching habpanel is containing both events.
Am I missing something obvious here, or should I start gathering logs, etc… ?
