- Platform information:
- Hardware: _Orangepi 3 LTS
- OS: Armbian 5
I would like to move the InfluxDB database off my SD card so I can move the entire installation to the eMMC memory of the Orangepi 3 LTS. The eMMC is about 8 GB and the SD card is currently 17 GB, of which 11 GB is InfluxDB data.
The process, that failed, was as follows:
- Mount the remote server folder to my Orangepi 3 LTS with sshfs
sshfs -o uid=116,gid=123 influxdb@remote.server.ip:/media/mnt/InfluxDB /var/lib/influxdb/engine/data.tmp
stop InfluxDB and OpenHAB services
rsync the InfluxDB database to the remote server
rsync -r -ah --info=progress2 data data.tmp
- Move the local data folder aside and create a new data folder for mounting
mv data data.old
umount data.tmp
mkdir data
- Mount the remote ip folder as local folder data
- Restart OpenHAB and InfluxDB services.
InfluxDB does not start:
Jul 24 19:04:34 orangepi3-lts systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261982]: Command "print-config" is deprecated, use the influx-cli command server-config to display the configuration values from >
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.902582Z lvl=info msg="Welcome to InfluxDB" log_id=0jEAALqW000 version=v2.7.1 commit=407fa622e9 bu>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.907097Z lvl=info msg="Resources opened" log_id=0jEAALqW000 service=bolt path=/var/lib/influxdb/in>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.907520Z lvl=info msg="Resources opened" log_id=0jEAALqW000 service=sqlite path=/var/lib/influxdb/>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261997]: Command "print-config" is deprecated, use the influx-cli command server-config to display the configuration values from >
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.921903Z lvl=info msg="Checking InfluxDB metadata for prior version." log_id=0jEAALqW000 bolt_path>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.922232Z lvl=info msg="Using data dir" log_id=0jEAALqW000 service=storage-engine service=store pat>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: ts=2023-07-24T16:04:34.922337Z lvl=error msg="Failed to open engine" log_id=0jEAALqW000 error="mkdir /var/lib/influxdb/e>
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: Error: mkdir /var/lib/influxdb/engine/data: file exists
Jul 24 19:04:34 orangepi3-lts influxd-systemd-start.sh[261981]: See 'influxd -h' for help
Jul 24 19:04:35 orangepi3-lts influxd-systemd-start.sh[262006]: Command "print-config" is deprecated, use the influx-cli command server-config to display the configuration values from >
Jul 24 19:04:35 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 1 attempts...
Jul 24 19:04:36 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 2 attempts...
Jul 24 19:04:37 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 3 attempts...
Jul 24 19:04:38 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 4 attempts...
Jul 24 19:04:39 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 5 attempts...
Jul 24 19:04:40 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 6 attempts...
Jul 24 19:04:41 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 7 attempts...
Jul 24 19:04:42 orangepi3-lts influxd-systemd-start.sh[261980]: InfluxDB API at http://localhost:8086/ready unavailable after 8 attempts...
This continues ad infinitum and makes me very confused. Why does this not work?
