Please let me know what can I do to not display all the lines that I got in the custom log file generated by Logging Persistent. I have the next configuration:
logging.persist:
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
default = everyChange
Items {
allTemperatures* -> "allTemperatures"
AllItems* -> "AllItems
openhab.cfg configuration
logging:pattern=%date{ISO8601} - %-25logger: %msg%n
Output of AllItems.log file
2016-03-30 11:13:56,364 - Dimmer_IarinaRoom_LEDs : 0
2016-03-30 11:13:56,375 - Switch_IarinaRoom_LEDs : OFF
2016-03-30 11:13:57,331 - IarinaRoom_LEDs_Power : 24.6
2016-03-30 11:13:58,334 - IarinaRoom_LEDs_Power : 0.3
2016-03-30 11:14:50,353 - Movement : OPEN
2016-03-30 11:16:40,453 - Movement : CLOSED
2016-03-30 11:16:40,810 - Movement : OPEN
2016-03-30 11:17:24,664 - Movement : CLOSED
2016-03-30 11:17:48,818 - Lux : 189
2016-03-30 11:18:58,446 - IarinaRoom_LEDs_Power : 0
2016-03-30 11:20:22,761 - Movement : OPEN
2016-03-30 11:20:53,640 - Movement : CLOSED
2016-03-30 11:23:45,738 - Movement : OPEN
2016-03-30 11:24:26,688 - Movement : CLOSED
So I want to not colect the lines with value “0” (e.g 2016-03-30 11:18:58,446 - IarinaRoom_LEDs_Power : 0) and lines with “CLOSED”.
Thank you,
Marian
