I have a binding installed (Gardena) that outputs the status as text from the sitemap:
String Gardena_Sileno_City__Status "Status [%s]" <lawnmower>
Text item=Gardena_Sileno_City__Status
The shown text is “Mähen”, “Suche Ladestation”, “Geparkt nach Zeitplan” and so on.
But when I output the status from a rule like
logInfo("Maeher", String::format("%s - %s changed to %s", triggeringItem.name, triggeringItem.label, Gardena_Sileno_City__Status.state.toString))
I only get “ok_cutting”, “ok_searching”, “parked_timer”.
In the sourcecode of the Gardena binding (Link), I found the definitions
channel-type.gardena.status.label=Mäherstatus
channel-type.gardena.status.description=Der Status des Mähers
channel-type.gardena.status.state.option.paused=Pausiert
channel-type.gardena.status.state.option.ok_cutting=Mähen
channel-type.gardena.status.state.option.ok_searching=Suche Ladestation
channel-type.gardena.status.state.option.ok_charging=Lädt
channel-type.gardena.status.state.option.ok_leaving=Mähen
channel-type.gardena.status.state.option.wait_updating=Wird aktualisiert ...
channel-type.gardena.status.state.option.wait_power_up=Wird eingeschaltet ...
channel-type.gardena.status.state.option.parked_timer=Geparkt nach Zeitplan
channel-type.gardena.status.state.option.parked_park_selected=Geparkt
channel-type.gardena.status.state.option.off_disabled=Der Mäher ist ausgeschaltet
channel-type.gardena.status.state.option.off_hatch_open=Deaktiviert. Abdeckung ist offen oder PIN-Code erforderlich
channel-type.gardena.status.state.option.unknown=Unbekannter Status
channel-type.gardena.status.state.option.error=Fehler
channel-type.gardena.status.state.option.error_at_power_up=Neustart ...
channel-type.gardena.status.state.option.off_hatch_closed=Deaktiviert. Manueller Start erforderlich
channel-type.gardena.status.state.option.ok_cutting_timer_overridden=Manuelles Mähen
channel-type.gardena.status.state.option.parked_autotimer=Geparkt durch SensorControl
channel-type.gardena.status.state.option.parked_daily_limit_reached=Abgeschlossen
channel-type.gardena.status.state.option.undefined=Undefiniert
So how can I get / output this “real” text, not only the status.option identifier?
