I’ve a question. I’m parsing data from a website, and the regex works quite good:
Number Http_Meteoalarm_TodayTest "MeteoAlarm [%d]" { http="<[https://www.meteoalarm.eu/en_UK/0/0/AT002-Vorarlberg.html/:5000:REGEX(.*aw.*?([0-9]+[0-9]+).*.?)]"}
The problem is when I have 2+ alerts … so I should have an array, but at the moment I can see only the last value. Any chance to have at least 3-4 items when I can collect 3-4 alerts maximum per site?
I’ve tried with:
Number Http_Meteoalarm_TodayTest "MeteoAlarm [%d]" { http="<[https://www.meteoalarm.eu/en_UK/0/0/AT002-Vorarlberg.html/:5000:REGEX(.*aw.*?([0-9]+[0-9]+).*.?[0])]"}
but I see always the second value, and not the first.
Given the item is a Number, what would you expect the Item’s state to be assuming you were able to match the rest results? A Number is just that, a single numbering value.
You can use a regex to capture the full “array” of values to a String Item and then a Rule to further spit it the values and assign then to their own unique Number Items.
If I well understood what you are suggesting, I should see the full “array” here. At this moment in time there are 2 alerts (aw53 and aw32), but in the string item I can see only the second one (32)
All I can suggest is you need to update the regex to capture all the data. I suggest using one of the many online regex testers to experiment until you get all the data.
I think you misunderstood what I was saying. OH regular expressions do not support multiple matches. So you need to write a regular expression that matches everything you want in one match.
What you have matches the full list, not each part of the list individually.
So if you have “aw53 aw32” as the list that you are trying to match against, you need a regex that looks something like .*([aw\d\s*]+).* which matches “aw” followed by one or more digits followed by zero or more spaces one or more times.
