I am working on a custom widget and I want to have a drop down box allowing the user to select five options (1 -aaaaaa, 2-bbbbb, 3-cccccc, 4-ddddddd, 5-eeeee). How do I populate the drop down box with static values? Here’s my test code:
uid: test_dropdown
tags:
card
props:
parameters:
description: Title for the widget
label: Static Title
required: false
parameterGroups: []
timestamp: Oct 11, 2021, 6:41:00 PM
component: f7-card
title: =props.title
slots:
default:
I’m no expert in widgets but in your original you were using an oh-input widget. You need to use an oh-list instead. Beyond that I know no more than what’s in the docs.
Another alternative is to use just a oh-button an use the options action.
This is, to my knowledge, far and away the best option. I’m not sure you even can produce the kind of dropdown input that you are thinking of through the widget system. The array of options required to display an f7-input as a dropdown are simply not available through the widget yaml.
The oh-button with the options action is going to be far more responsive to different screen sizes and formats anyway and all the work integrating the buttons values with OH are already done for you instead of the convoluted steps required with the f7-input.
Using an oh-list with an accordion setup you could simulate a dropdown but it’s a kludge that will likely have downstream effects you don’t like (such as shifting other widgets when it opens since the accordion rows are not overlays).
Thanks for the advice. It’s very frustrating because the oh-input acts as a drop down, but there’s no data in the overlay list. I’ve lost the will to live and changed it to a slider.
