Helo there!
I would like to ask, how to protect the acces to your server.
When you open the port from your router, you get access from outside to your openhab server, but there is any way to get a login page before get in the setup openhab page?
I have seen that you can set a paswwor in the user.properties file, but this is nor working.
As sihui already pointed you to the docs - please do read it carefully!
openHAB is not intended to be used with an open port - unless you’re a security expert and know exactly what you’re doing.
The benefit of openHAB simply comes from the fact, that it is your INTRAnet of Things - your smarthome shouldn’t be open to the Internet at all costs. of course there are a few Options in the doc-page, to make it accessible via you phone, if you’re not at home - but never expose anything in your private network at home to the Internet - unless it’s safe and you know it!
EDIT: I have read about myopenhab but still having this doubt.
using myhopenhab, actually, I would be using the openhab servers or mine one? or it is like a bridge between my device outside and my server within home?
My intention was to create a server to avoid third parts servers… like WeLink Netatmo …and others
