How to read metadata in widget
Hello openHAB Community :wave:,
as an openHAB newbie I tried to read an item’s metadata in a Label Card Widget.
I tried the following:
component: oh-label-card
  item: NewItem
  label: =items['NewItem'].metadata.example
slots: null
I’ve created the custom metadata namespace example with the value of test. It also does work with the JavaScript Binding via items.getItem('NewItem').getMetadata('example').value.
The above snippet results in the following error:
TypeError: Cannot read properties of undefined (reading ‘example’)
Am I missing something? Any ideas?
Metadata is not directly accessible, you can retrieve it from a oh-repeater.
Thanks, that works.
