I am working on an update to an hdmi-cec binding that code was posted for. I am having some wierd effects that are hard to figure out with debug log entries.
The target device is a raspberry pi, running the pre-built image.
I am developing with eclipse on windows. I don’t run openhab locally as i don’t have the hdmi setup needed to test with.
if i run start_debug.sh it complains about a root instance already running. if i kill that with servicectl, and then try the shell script, it fails with not finding the user profile stuff it needs. ( sorry i am being vague, i’m tapping this out on my phone in a free minute, and i’m not at my PC.
Remote debugging is not possible with the default openHAB. You would need to start the karaf container that starts all the bundles in a specific way. See Apache Karaf 2.4.5-SNAPSHOT Guides
I had this one many times. Temporarily put catch(Throwable e) around suspicious code. Catching Throwable is not recommended but in real life bookish rules don’t help. So called “ugly” code helps.
