I just figured out that mqtt text channels always include the quotes:
So in OH it appears as:
Question: How can I get rid of the quotes at the beginning and the end of the string?
I looked into incoming transformation but couldn’t it figure out
A simple REGEX should work.
REGEX:"(.*)"
This one was super easy. Thanks are enough. Glad it’s working for you!
Btw: Is it also possible to do a map transformation on the regex in one step or do I have to use the state metadata of the item instead?
You can chain transformations. If it’s a switch, there’s the “custom ON/OPEN value” and “custom OFF/CLOSED value” fields also.
