Hi folks,
I need to reset totally my aeon Stick S2, erase all previous configuration (and nodes present today in the nework), then re-include one by one.
What is the best procedure?
openHAB 2.3.0 1234
thanks
Andrea
Hi folks,
openHAB 2.3.0 1234
thanks
Andrea
Go to HABmin, select your controller, go to “Advanced settings”, click on “Hard Reset controller”.
Reset all your devices to factory default (or exclude them properly before hard resetting the controller), then include your devices one by one.
After that adjust your config to the new node numbers. Don’t forget to use the same node name for your controller thing or you will have to adjust those too after resetting.
I’ve also removed all nodes.xml (except node.1) … and it seems it fixed my issues.
fingers crossed
thanks for your answer
Andrea
the issue is still here, I will open a new thread for that
thanks
Andrea
