I tried it as example with:
rule "switch off release buzzer"
Item ShlPiGeneral_Shutdown received command ON
createTimer(now.plusMillis(1000), [ |
ShlPiGeneral_Shutdown.sendCommand(OFF)
Item ShlPiGeneral_Reboot received command ON
ShlPiGeneral_Reboot.sendCommand(OFF)
I found it here. Also there I found the solution that I can use a Switch as a Button. But the problem is not solved.
Remember I used this inside the sitemap:
Switch item=ShlPiGeneral_Reboot icon="exec_restart" label="shlPiGeneral neustarten" mappings=[ON="Neustarten"]
And inside the items I used a string:
String ShlPiGeneral_Reboot "shlPiGeneral Reboot" (gSystemInfoShlPiGeneral) { channel="exec:command:openhabianShlPiGeneral_reboot:input" }
Another approach was:
Item ShlPiGeneral_Reboot changed
if (ShlPiGeneral_Reboot.state == ON) {
I think it`s because of the String. I am not sure how to make a better solution. Hopefully there is someone who can help me. Thanks in advance.
