Platform information:
- Hardware: virtual Machine on ESX Server
- OS: Suse Linux Enterprise Server 15
- Java Runtime Environment: zulu8.33.0.1-jdk8.0.192
- openHAB version: 2.4.0
Issue of the topic: OpenHAB extensions (OpenHABCloud, Telegram) can’t connect to their servers
Please post configurations:
- Services configuration related to the issue
/etc/default/openhab2
has EXTRA_JAVA_OPTIONS set to this:
EXTRA_JAVA_OPTS="-Djava.net.useSystemProxies=true -Dhttp.proxyHost=[my proxy IP] -Dhttp.proxyPort=8080 -Dhttp.nonProxyHosts='localhost|127.0.0.1|.local'"
If logs where generated please post these here using code fences:
# systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2019-12-10 09:19:47 CET; 26s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 15107 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 15361 (java)
Tasks: 165 (limit: 4915)
Memory: 420.3M
CPU: 32.714s
CGroup: /system.slice/openhab2.service
└─15361 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djava.library.path=/var/lib/openhab2/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8084 -Djava.awt.headless=true -XX:+UseG1GC -Djava.net.useSystemProxies=true -Dhttp.proxyHost=[my proxy IP] -Dhttp.proxyPort=8080 -Dhttp.nonProxyHosts='localhost|127.0.0.1|.local' -Djava.endorsed.dirs=/usr/lib/jvm/zulu-8/jre/lib/endorsed:/usr/lib/jvm/zulu-8/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/zulu-8/jre/lib/ext:/usr/lib/jvm/zulu-8/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/var/lib/openhab2/tmp/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.logs=/var/log/openhab2 -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/activation-1.1.1.jar:/usr/share/openhab2/runtime/lib/boot/jaxb-api-2.3.0.jar:/usr/share/openhab2/runtime/lib/boot/jaxb-core-2.2.11.jar:/usr/share/openhab2/runtime/lib/boot/jaxb-impl-2.2.11.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.2.1.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.2.1.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.2.1.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
Dec 10 09:19:47 systemd[1]: Started openHAB 2 - empowering the smart home.
OpenHAB Log shows this:
==> /log/openhab2/openhab.log <==
2019-12-10 09:21:09.324 [INFO ] [e.smarthome.model.script.debug.rules] - Sending Telegram message...
2019-12-10 09:29:52.416 [WARN ] [ab.action.telegram.internal.Telegram] - Transport error: {}
java.net.ConnectException: Connection timed out (Connection timed out)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666) ~[?:?]
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:471) ~[?:?]
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(SSLSocketFactoryImpl.java:153) ~[?:?]
at org.apache.commons.httpclient.protocol.SSLProtocolSocketFactory.createSocket(SSLProtocolSocketFactory.java:82) ~[?:?]
at org.apache.commons.httpclient.protocol.SSLProtocolSocketFactory.createSocket(SSLProtocolSocketFactory.java:127) ~[?:?]
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) ~[?:?]
at org.openhab.action.telegram.internal.Telegram.sendTelegram(Telegram.java:100) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:341) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
What do I do wrong?
