How to send email when a condition is met?
Please show a noob the rules needed to send an email when temp reaches or exceeds 25 degrees or drops to 15 degrees or lower for the node listed below .
email has been configured and is working with other rules.
Number esp_fermenter_temp “Fermenter/Beer Cooler Temperature [%.2f Degree’s Celsius]” <temp_icon> (esp4) {mqtt="<[mymosquitto:/FermoStat/Fermenter_Temp/Fermenter_Temperature:state:default]"}
Cheers
Hi Dave,
i am using this rule for a push notification in a similar case. i think you can use this also by changing the items:
rule "Luftfeuchtigkeit_Badezimmer_zu_hoch"
	Item Tado_zone_Badezimmer_Humidity changed
	if (Tado_zone_Badezimmer_Humidity.state >= 60 && previousState <  60) {
		sendBroadcastNotification(
		"Im Badezimmer ist die Luftfeuchtigkeit zu hoch ("+Tado_zone_Badezimmer_Humidity.state+"%).")
rule "Luftfeuchtigkeit_Badezimmer_wieder_ok"
	if (Tado_zone_Badezimmer_Humidity.state < 60 && previousState >=  60) {
		"Im Badezimmer ist die Luftfeuchtigkeit wieder ok ("+Tado_zone_Badezimmer_Humidity.state+"%).")
Thanks Alexander.
I will play with it.
Regards
