I need help with pushover from ecmas script. For a dsl script this works:
val actions = getActions(“pushover”, “pushover:pushover-account:888xxdfca2”)
var receipt = actions.sendMessage(“HELLO!”, “PLEASE”)
for an ecmascript, which would be correct ?
Thank You
JustinG
(JustinG)
#2
You can use the get method of the built-in actions
object in a similar way to the getActions
function you were using.
actions.get(“pushover”, “pushover:pushover-account:888xxdfca2”).sendMessage(“HELLO!”, “PLEASE”);
note: because actions
is a built-in object you should avoid creating your own variable of the same name in your script.
