Hi, How can I configuration mqtt-eventbus to send only those topics whose state are changed using configuration done in mqtt-eventbus.cfg.
simply: you can’t.
it’s called “eventbus” - meaning all items will pushed through.
You can always only add a mqtt-message on items only:
Item itemName { mqtt="<direction>[<broker>:<topic>:<type>:<trigger>:<transformation>]" }
see the docs for more Information
https://docs.openhab.org/addons/bindings/mqtt1/readme.html
