How to set a simple timer
Cron expression is string used to specify schedule,
You can use cron expression in rules, as time-based trigger.
So you put it after when clause in rules syntax
rule "<RULE_NAME>"
    <TRIGGER_CONDITION> [or <TRIGGER_CONDITION2> [or ...]]
    <SCRIPT_BLOCK>
And you can define the needed cron expression manually (after reading about it) or by using this website (https://www.freeformatter.com/cron-expression-generator-quartz.html),
