I am struggling with my homematic rollershutter actors which operate “raffstores” (are these called "persian blinds?, I don’t know) While these actors accept commands to set a position (e.g. 50%, 25%), they cannot set the blinds to a specific angle. Has anyone tries something similar? Here’s what I came up with:
I created a rule that (after an update of state) sends an “UP” command to the blind and then after half a second or so stops the blind again. This is basically what you would do manually. That works fine so far and puts the blind to the desired angle. BUT: The rule itself sets the blind to a new state and therefor gets fired again, and again, and again, and I end up with a command sent to the blind every half second:
excerpt from my RULE:
if (Raffstore_Gast_OG_Level.state >= 40 && Raffstore_Gast_OG_Level.state <= 98) {
sendCommand(Raffstore_Gast_OG_Level, UP)
Thread::sleep(300)
sendCommand(Raffstore_Gast_OG_Level, STOP)
Is there any possibility to see if the command comes from a switch or if the command is generated by a rule or by a “sendCommand”?? Any Idea?
Cheers, Thomas
