I tried to use the PiFace on my Raspi which I can do on command line using Python.
When I activate the PiFace binding and items I get:
2016-01-02 15:20:17.251 [ERROR] [.piface.internal.PifaceBinding] - Failed to send command (14) to 192.168.178.204:15432 (attempt 3)
java.net.SocketTimeoutException: Receive timed out
at java.net.DualStackPlainDatagramSocketImpl.socketReceiveOrPeekData(Native Method) ~[na:1.8.0_66]
at java.net.DualStackPlainDatagramSocketImpl.receive0(Unknown Source) ~[na:1.8.0_66]
at java.net.AbstractPlainDatagramSocketImpl.receive(Unknown Source) ~[na:1.8.0_66]
at java.net.DatagramSocket.receive(Unknown Source) ~[na:1.8.0_66]
at org.openhab.binding.piface.internal.PifaceBinding.sendCommand(PifaceBinding.java:298) [bundlefile:na]
at org.openhab.binding.piface.internal.PifaceBinding.sendCommand(PifaceBinding.java:268) [bundlefile:na]
at org.openhab.binding.piface.internal.PifaceBinding.sendWatchdog(PifaceBinding.java:233) [bundlefile:na]
at org.openhab.binding.piface.internal.PifaceBinding.execute(PifaceBinding.java:98) [bundlefile:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) [org.openhab.core_1.7.1.jar:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) [org.openhab.core_1.7.1.jar:na]
So the message is quite clear, raspberry does not listen on these ports. But where do I set them or what needs to be started on raspi to establish these listeners?
br Matthias
