I have some underfloor heating valves, which i wanna show status on in the UI - but not allow the user to change state on theese… That’s only the logics that can do this…
My question is then, should i define them as a switch or something else like a “contact” so i have the ability to show it as “Closed” or “Open”? - or maybe a cool icon… i guess i then have to make it as a switch - but how to “disable” the function to press it?
Unfortunately listing everything on your sitemap as a Group precludes you from doing any sort of customizations. You will have to list each Item in that group individually. Once you do so you can put them on your sitemap as a Text element.
