What version of openhab are you running?
OPenhab 2.3 on RPi3 with openhabian
My bad, the two rules have the same name!!
rule "Garage door direction1"
Status_Garagentor_close changed to OPEN or //Door opening
Status_Garagentor_open changed to OPEN //Door closing
if (triggeringItem.name.toString == "Status_Garagentor_close") Status_Garagentor.postUpdate("OPENING")
if (triggeringItem.name.toString == "Status_Garagentor_open") Status_Garagentor.postUpdate("CLOSING")
rule "Garage door direction2"
Status_Garagentor_close changed to CLOSED or //Door closed
Status_Garagentor_open changed to CLOSED //Door open
if (triggeringItem.name.toString == "Status_Garagentor_close") Status_Garagentor.postUpdate("CLOSED")
if (triggeringItem.name.toString == "Status_Garagentor_open") Status_Garagentor.postUpdate("OPEN")
Just to show a way of doing this
My items
Switch GarageDoorSwitch [ "Switchable" ] { mqtt=">[broker:cmnd/GarageDoorSonoff/POWER:command:*:default]" }
Rollershutter GarageDoor
String GarageDoorState
Switch GarageDoorClosed { mqtt="<[broker:cmnd/GarageDoorSensors/POWER1:state:default]" }
Switch GarageDoorOpened { mqtt="<[broker:cmnd/GarageDoorSensors/POWER2:state:default]" }
Number Garage_RSSI "Garage: RSSI [%d %%]" { mqtt="<[broker:tele/GarageDoorSonoff/STATE:state:JSONPATH($.Wifi.RSSI)]" }
String Garage_IP "Get Info" { mqtt=">[broker:cmnd/GarageDoorSonoff/IPAddress1:command:*:*]" }
String Garage_IP_String "Info [%s]" { mqtt="<[broker:stat/GarageDoorSonoff/RESULT:state:default]" }
Switch GarageDoorAuto "Garage Door auto close 9PM-5AM"
Switch GarageDoorStateUpdate { mqtt=">[broker:cmnd/GarageDoorSonoff/STATUS:command:*:10]" } //hidden button to get update of garage door status. Runs every minute
String GarageDoorStateString { mqtt="<[broker:tele/GarageDoorSonoff/SENSOR:state:default]" } //hidden string to be updated depending on status
sitemap
Text label="Garage" icon="garage"
Frame label="Control"
Switch item=GarageDoor label="Garage Door" icon="garagedoor"
Frame label="Status"
Text item=GarageDoorState label="[%s]" icon="garagedoor" valuecolor=[GarageDoorState=="Closed"="green",GarageDoorState=="Open"="red",GarageDoorState=="Ajar"="orange"]
Text label="Settings" icon="settings"
Switch item=GarageDoorAuto icon="time"
rules
var Timer garageDoorTimer
var Timer garageDoorOpenTimer
//*************************************************************************** Garage Door Rules Below********************************************************************
rule "Garage Door Open"
Item GarageDoor received command UP
if (garageDoorTimer !== null)
garageDoorTimer.cancel
garageDoorTimer = null
if (GarageDoorOpened.state != ON)
GarageDoorSwitch.sendCommand(ON)
garageDoorTimer = createTimer(now.plusSeconds(25)) [|
if (GarageDoorOpened.state != ON && GarageDoorClosed.state == ON)
rule "Garage Door Close"
Item GarageDoor received command DOWN
if (garageDoorOpenTimer !== null)
garageDoorOpenTimer.cancel
garageDoorOpenTimer = null
if (GarageDoorClosed.state != ON)
if (GarageDoorClosed.state != ON && GarageDoorOpened.state == ON)
rule "Garage Door Stop"
Item GarageDoor received command STOP
if (GarageDoorClosed.state != ON && GarageDoorOpened.state != ON)
rule "Garage Door State"
Item GarageDoorClosed received update or
Item GarageDoorOpened received update
Thread.sleep(500)
if (GarageDoorClosed.state == ON && GarageDoorOpened.state == OFF)
GarageDoor.postUpdate(DOWN)
GarageDoorState.postUpdate("Closed")
if (GarageDoorOpened.state == ON && GarageDoorClosed.state == OFF)
GarageDoor.postUpdate(UP)
GarageDoorState.postUpdate("Open")
if (GarageDoorClosed.state == OFF && GarageDoorOpened.state == OFF)
GarageDoor.postUpdate(50)
GarageDoorState.postUpdate("Ajar")
rule "Garage Door Button Timer"
Item GarageDoorSwitch received command ON
createTimer(now.plusSeconds(1)) [|
GarageDoorSwitch.sendCommand(OFF)
rule "Garage Door Auto Close"
Time cron "0 0/6 21-5 1/1 * ? *"
if (GarageDoorAuto.state == ON)
sendBroadcastNotification("Garage door will shut in 5 minutes")
garageDoorOpenTimer=createTimer(now.plusMinutes(5)) [|
sendBroadcastNotification("Garage door has closed automatically")
GarageDoor.sendCommand(DOWN)
rule "Garage Door Auto Close Switch "
Item GarageDoorAuto received command OFF
rule "Garage Door Opening"
Item GarageDoorClosed changed from ON to OFF
sendBroadcastNotification("Garage Door has opened!")
rule "Garage Door Closing"
Item GarageDoorOpened changed from ON to OFF
Thread::sleep(500)
sendBroadcastNotification("Garage Door is Closing!")
Basically. I have a switch which literally sends the MQTT command,
I use a ruller shutter item to have UP X DOWN as commands.
I then run rules to check if the garage is down, and i press down, nothing happens, If the garage is up and i press up, nothing happens. And the X button only works if the garage is neither opened of closed.
I also have 2 reed switches, one for open, one for close.
I have another rule. which when i press either up or down, it sends the command to activate the garage. if after 25 seconds, it hasn’t activated the reed switch i wanted, (either opened or closed depending what i pressed), it will press the garage button one time. If for instance, there is something blocking the door from moving, it wont run the rule again, as I pressed the garage button, not pressed up/down again.
I also have timers, and auto closing after certain times. as you can see in my rules
Nice one, did not think about that. Will implement this too, thx. ![]()
Hi Vincent
this doesn´t solve the problems, ist still:
no viable alternative at inpot…
and
the method or field triggeritem is undifined.
Christopher thank you for your very welcome input.
I will need some time to see how I can implement your rules as I use two KNX contacts to open and close the carage door and to reed an a KNX sensor to read the status.
Furthermore I´m not sure how these rules handle Inputs from remote, or in my case from usual KNX switches.
THX
Daniel
@Daniel_OH
Can you publish your items and rules, please
Please use the code fences
Items
Switch Garagentor_open "Garagentor" (gAussen) [ "Switchable" ] {knx="5/1/2+<10/3/2"}
Switch Garagentor_close "Garagentor" (gAussen) [ "Switchable" ] {knx="5/1/1+<10/3/1"}
Switch Haustuere "Haustüre" (gAussen) [ "Switchable" ] {knx="5/1/0"}
Contact Status_Garagentor_open "Garantor offen " <Garagedoor> (gAussen) [ "Switchable" ] {knx="4/3/1"}
Contact Status_Garagentor_close "Garantor geschlossen " <Garagedoor> (gAussen) [ "Switchable" ] {knx="4/3/2"}
String Status_Garagentor "Status Garagentor"
Rule
THX
rule "Garage door opening"
Status_Garagentor_close changed to OPEN //Door opening
rule "Garage door closing"
rule "Garage door closed"
Status_Garagentor_close changed to CLOSED //Door closed
rule "Garage door open"
Sorry fore the late respond, was on holydays.
I´m really sorry but I dont get it. Its still the same
no viable alternative at input ‘Status_Garagentor_close’ (3,5)
no viable alternative at input ‘Status_Garagentor_open’ (10,5)
no viable alternative at input ‘Status_Garagentor_close’ (17,5)
no viable alternative at input ‘Status_Garagentor_open’ (24,5)
Found the problem
Just had to add Item before “Status_Garagentor”
Thank you very much. You helped me a lot Vincent
I can’t believe I missed that!!
