How to set y-axis on oh-label-card trend line?
hi,
how can i change range value of a trend line?
For example: barometric pressure go to 0 to 1200mbar but i want change in 800-1200.
thanks to all.
At present, you cannot. That requires parameters to the vue-trend component that are not currently available in the config. If you really want this feature you’ll have to put in a feature request on the github repo or give a go at adding it yourself.
ok, thank you very much
