I am new here, so first of all thanks a lot for all the awesome work that goes into this project!
I am really excited to start playing around with Openhab and to see what it is capable of.
What I wanted to do was to get an idea how Openhab 1.7 worked and debug a binding.
I setup the IDE following the “yoxos instructions” and got everything to build ok.
But I can’t for the life of me figure out how to start a debug sesssion.
My assumption is that I have to start the ./start_debug.sh script in the ./distribution/openhab folder and then connect with the eclipse remote debugger.
If this is true, my first problem is what I should set the eclipsehome variable to?
I tried setting it to my yoxos home path. But if I do that I am stuck at: Listening for transport dt_socket at address: 8001
This is probabaly the time to confess that I am new to Java too, so this might be something competely obvious to somebody who knows what they are at.
I am also happy to read some primers on this subject if you have any good recommendations. I just don’t really know where to start at the moment.
Can somebody please give me a step by step guide for dummies to debugging a binding?
In case anybody else has a basic problem like this here is what I did.
I started from scratch according to the yoxos method.
After everything was setup according to the wiki page I copied the “openHAB Runtime” run configuration to create a “openHAB Runtime -Debug” configuration.
For the new configuration I added following options to the “VM options” field on the “Arguments” tab: -Xdebug -Xrunjdwp:transport=dt_socket,address=8001,server=y,suspend=y
(suspend=y will cause execution to stop until a debugger is attached).
Then I created a new remote debug configuration with the corresponding server settings (server: localhost port:8001).
And that is pretty much it!
To debug simply run the “openHAB Runtime - Debug” configuration and then start the “Remote Debug” session.
The configuration folder that is taken into account for this run is located here: openhab/distribution/openhabhome/configurations/
Thank you for this explanation. I am going to give it a try. Some things are not very clear to me, probably because I have not yet read the wiki page you are referring to.
Carl
Hi narodo,
Thank you for your detailed post.
I think I do the same thing as your post described in my eclipse, However, I get this error message ERROR: Cannot load this JVM TI agent twice, check your java command line for duplicate jdwp options. Error occurred during initialization of VM agent library failed to init: jdwp
Actually I am pretty new to java. I think this problem may be trivial for expert java developer.
Thank you and any information will be greatly appreciated.
